2005-01-03
07:41 PM
- last edited on
2025-02-10
04:09 PM
by
Aruzhan Ilaikova
2005-01-03 07:48 PM
Nathan wrote:What is the scale of your DWG? It usually comes in 1:1.
I am comparing some dwg files and using plotmaker to print them superimposed. But nothing is showing up.
I see title block, and Plotmaker linework, but no DWG. I checked pens, and they are the same as PM linework.
Any ideas?
Nathan
2005-01-03 08:40 PM
2005-01-06 06:17 PM
Nathan wrote:You don't see what you want to print. Your DWG is patially outside of the layout. What you print is the layout.
I was unclear.
On screen, I see exactly what I want to print.
On paper and in PDF, I get no DWG. I also didn't say that these are Autocad 2005 DWGs, which is what I am about to test next.
Scale, Location, is all good as far as I can tell.
Also, I can explode the DWG, and then it prints, but that is not satisfying to me, since I loose the link.
Nathan
2005-01-06 06:30 PM
2005-01-06 06:31 PM
