2020-09-08
02:19 PM
2023-05-30
12:22 PM
Rubia Torres
2020-09-14 09:36 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-09-14 09:48 AM
2022-08-09 01:22 PM
I'm having the same issue - Using linked markers rather than source markers to link to a worksheet of details but if I change the Drawing ID of the placed worksheet view, the detail marker does not update without opening the settings and closing them again or moving the marker around. Has anyone found a fix?
2022-08-17 01:59 PM
Hi Olivia,
I'm sorry to hear that you are having this issue!
Past investigation showed that the issue is most likely happening in Teamwork environment. May I ask you if that is the case?
If not I would like to ask you to try and reproduce the problem in a new file and share the steps with us in detail.
Looking forward hearing from you!
Kind regards,
Dani Benjamin
2023-04-27 03:09 PM
I'm having the exact same problem as OliviaJE.
And yes it is happening in Teamwork environment. What does that mean and are there any solutions?
This is a serious shortcoming which has caused our office to send out mislabeled drawings. We are now forced to manually review and cross check all drawings and correct these issues. If we can't rely on Archicad to handle links then that time cost and uncertainty alone renders it useless for most projects.
Regards,
