C_Gold
Diffrent 3D Detail-Level Display of Objects on 3D Document
Hello everyone,
Is there a way to display objects (furniture) on a 3D document in a different level of 3D detail than in the entire model?
I would like to display the objects (furniture) for an axo in a simplified way, but only on the 3D document for the axo and not in the entire model.
Thanks in advance !
Constantin
1 Reply 1
aarkell
This could be handled via separate model view options, one with objects set to show 3D as "Full" and another as "Simplified" or "Schematic". You can modify that setting for objects/lamps under the "Miscellaneous Settings for Library Objects" in the MVO settings, and will want to make sure that the 3D Detail level for your furniture objects is set to "By MVO" in the object settings.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
