Dimension background
I'm pretty sure there is a way to clear the background for the dimension text box when placing it against background fills but for the life of me I can't remember how. Help?
David Maudlin
Kingfish60:
If you are still on AC19, then look at Dimension Settings > Type and Font > Opaque. AC22 has the same setting under Text Style.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Kingfish60:
Thank You.
