Loren Green
Dimension nodes disappearing
When I attach a dimension to the core of a wall on the non-reference side then the dimension node disappears when I click out of the view. If the node is attached to a skin or the reference side of the core it won't.
Is anyone else experiencing this. This has got to be a bug.
AC 25 Full build 4013 US windows
13 Replies 13
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Dear Loren,
I have sent you the link via Private Message. Please let me know once the file is uploaded.
Thank you very much!
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
b_almquist
Hi Minh,
Sorry for the very late reply. We're not seeing this in projects started on AC 25 but it's also not specific to one project file. Others that were started in AC 23 are having the same issue. I can share the project file privately. A secure place to upload the file would be very helpful.
MacBook Pro 13" - 2019
2.8GHz quad-core i7 w/ 16GB
AC21-25
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hello,
Thank you very much for your answer!
After some investigation, we think that this issue is related to defect DEF-7210, which was fixed in Archicad 25 Update 3 (build 5005). I'm wondering if you open the project started in AC23 in Archicad 25 Update 3, will the problem persist?
Looking forward to hearing from you!
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
b_almquist
That seems to have resolved the issue.
Thanks Minh.
AC21-25
