Dimensioning and room names
Does anyone know how to add room names under the dimension lines. without having to add a seperate text block?
7 REPLIES 7
Srinivas
The only way I know of doing this is using a library part " Room Names 3de" which adds the room name based on the zone name.
More details here : http://4dlibrary.com.au/library/2009/04/room-names-for-dims-4d/
www.bimvizstudio.com
ArchiCAD Service
ArchiCAD since v9 to latest
Mac, Windows 11
Version 14 now has the ability to use custon text and the dimension will now change when the walls are adjusted unlike in previous versions.
But the room name is on the same line as the dimension and cannot be placed underneath.
Srinivas
It would be nice if we have the option to start the custom text by adding something like "\n" to the dimension text which essentially in many programs means to the compiler to go to a next line.
ArchiCAD Service
Mac, Windows 11
If you create a wish, Ill back you up on it. Id say quite a few others will too.
Erika Epstein
This has been wished for, but it would be great to renew this wish.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Ok. No problem Ill create a new wish and see how it goes.
Need everyones support on this.
If you visit http://archicad-talk.graphisoft.com/viewtopic.php?t=34108 you will be able to vote on this wish.
