Dimensioning in AC15
Hello,
since the update to AC15 i'm having problems with dimensioning in AC15.
When i pick points to measure i can't make it parallel [see attached screenshot]
I'm using standard ArchiCAD settings - please give me a hint how to deal with it.
Is it possible that dimensioning in AC15 changed somehow?
My drawing isn't rotated, it's aligned strictly to XY
Kamil
4 REPLIES 4
David Larrew
Before clicking your final dimension line placement, just click on an element or line that you want to align (parallel to) to lock the orientation.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
David Maudlin
Kamil:
There is a bug (I don't know if it was fixed in the latest hotfix). Go to Grids & Backgrounds and in the lower left corner change Rotation Angle to 0.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Steve Jepson
I find that when I open an AutoCAD .dwg with ArchiCAD or even import a .dwg xref into ArchiCAD I can not add horizontal dimensions with out resetting the Rotated Grid. Nothing changes visibly but the problem goes away when I Set Rotated Grid.
To do this I do click on the Set Rotated Grid button on the Coordinates palette. Left click on the drawing space, move the cursor horizontal holding down the shift key, left click again. This should rest the Rotated Grid and you should be able to add horizontal dimensions again.
Why this happens when I open an AutoCAD .dwg I don't know.
Thanks a lot! Problem solved!
