Dimensions not working at all after Archicad 27 update to Build 5060
Francois_MCD
Hi Graphisoft team
Dimensions are not working at all on my 1st use of Archicad 27 after the update to Build 5060 on my Windows 11 Home (23H2) computer.
See in the video, Dimension tool highlights the elements, but the dimension points are not created, so no dimensioning is happening at all.
I saved the file, re-opened it with repair (it did do some repairs) and saved it again, then tried the dimensions again but it's still not working.
Is this a known bug?
https://www.youtube.com/watch?v=_cgEUFoBaWk
Operating system used: Windows 11 23H2
Regards
Francois Swanepoel
Everything happens in Archicad since v6.5 (2000) ‌
Hiking, Motorbiking, Good food, Gr8! Beer & excellent conversation 😉
#MadeByDyslexia is my unfair advantage – expect curious ideas, creative big thinking & small typos.
<> www.fusionBIM.co.za <> www.Scirrus.co <> www.BIM2fusedVR.com <> (new) Anatomy of Archicad Course
Hi @Francois_MCD,
I guess it's not a bug, after watching your video I noticed you accidentally chose (Arc Length) as a dimension geometry method rather than (X-Y or Any Direction) one, as attached below.
AC 28 INT 3110/WIN 11
Hi @Francois_MCD,
Thanks @Mahmoud Qenawi I totally missed that and it's so obvious.
Regards
Francois Swanepoel
Hi @Francois_MCD,
You’re welcome, thanks for sharing your case I personally learnt from🙂.
Setup info provided by author
