Views, layouts, publishing: seamless Archicad documentation
Display Order in Section/Elevation views - No value check / Value defaults itself
Hi AC Software Testers and QA Engineers,
I was adjusting Display Order in Section views (Teamwork and regular files), but another time I open file, elements that had Display Order adjusted defaults to original Display Order level. I was trying to figure out what is happening but it looks like information about Display Order in "Element Information" showing wrong "Display order level" value no matter to what level I put elements in section/elevation views.
In the example below I chosen "Send to Back" and "Display Order Level" value still remains "6".
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v28 INT / NOR (5030)
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
1 REPLY 1
It works slightly differently in elevation to what it does in plan.
In plan send to back will move a line to level 1.
In elevation it will go to level 6.
But press it again it will go to 5 then 4 then 3, etc.
Don't ask me why.
