Is there a way to combine two existing vectorial fills into one new fill?
For example, a concrete fill combined with a parallel line fill?
Or would I have to create a new fill from scratch?
Thanks in advance...
Graphisoft Certified BIM Manager
AC27 USA - build 6000 - HP ZBook 15 G6 - Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM - Windows 10 Pro
1 Solution
Eduardo Rolon
Not besides placing one on top of the other with the background pen for the one on top set to transparent.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
6 Replies 6
Eduardo Rolon
AC29 US/INT -> AC08
Thanks, that's what I'm already doing. I'll just create a new fill from scratch
William Yan
I use autocad to export a dwg file which has this reinforced concrete hatch into Archicad.  It become a new fill type. And copy this new fill type to my template.
AC 26 5002 CHI, Windows 10
Patrick Hayes
Hey Kelly,
I believe you can only create a "Symbol fill". Archicad seems to have hardwired Vectorial fills which can only be duplicated and then stretched / adjusted, but not created from scratch.  You could dig around some of the other language version templates and there might be the fill in there as a vectorial fill... bit of a long shot though and easy to create a new symbol Fill
Associate | Law Architects
Melbourne, Australia
Thanks everyone, I created a few new symbol fills to go with my graphic override, and now my stepped walkout foundation walls have different fills based on their home offset distance. No more drawing a fill on top of a wall to achieve the same thing!
Thanks, but I haven't touched autocad in 20 years and avoid it at all costs!
