Is there a way to combine two existing vectorial fills into one new fill?
For example, a concrete fill combined with a parallel line fill?
Or would I have to create a new fill from scratch?
Thanks in advance...
Graphisoft Certified BIM Manager
AC27 USA - build 6000 - HP ZBook 15 G6 - Intel(R) Core(TM) i7-9850H CPU @ 2.60GHz, 16GB RAM - Windows 10 Pro
Eduardo Rolon
Not besides placing one on top of the other with the background pen for the one on top set to transparent.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
6 REPLIES 6
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
Thanks, that's what I'm already doing. I'll just create a new fill from scratch
William Yan
I use autocad to export a dwg file which has this reinforced concrete hatch into Archicad.  It become a new fill type. And copy this new fill type to my template.
AC 26 5002 CHI, Windows 10
Patrick Hayes
Hey Kelly,
I believe you can only create a "Symbol fill". Archicad seems to have hardwired Vectorial fills which can only be duplicated and then stretched / adjusted, but not created from scratch.  You could dig around some of the other language version templates and there might be the fill in there as a vectorial fill... bit of a long shot though and easy to create a new symbol Fill
Associate | Law Architects
Melbourne, Australia
Thanks everyone, I created a few new symbol fills to go with my graphic override, and now my stepped walkout foundation walls have different fills based on their home offset distance. No more drawing a fill on top of a wall to achieve the same thing!
Thanks, but I haven't touched autocad in 20 years and avoid it at all costs!
