Door/Window Markers in Elevation!
Anyway you can turn on your window and door markers for your Elevations??
25 Replies 25
Stress Co_
It works for me in new AC17 projects and a legacy project started in AC16.
Going back to the AC13 project (the one from my earlier screen shot)... it didn't work.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Stress Co_
Just noticed, you used a different Label than I.
Try "Label Window Marker 17"
And to confirm, "Label Door Marker 17" gets rotated.
aahatimo
"Stress Co."
And to confirm, "Label Door Marker 17" gets rotated.[/quote wrote:
marc, still does not work with me in doors perpendicular to plan, using label door marker 17.
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Stress Co_
As far as I can tell, the only difference between the Door marker & the Window marker is the name and …. the Window marker works and the door marker doesn't.
The work-a-round solution is to not use the Door marker.
EDIT:
So, to amend my 8/5/13 post…. the door label "bug" wasn't fixed.
Brad Elliott
Yep,
Good to know. Thanks
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Stress wrote:
Do you see this?:
Gave up trying to get this to work on archicad 16. Now have archicad 17 so thought Id give it a try.
I still have the same problem.
in response to to Stress Co - no I don't have the same list as you.
I've attached a screen shot of the options available to me.
As you can see window marker isnt listed.
Should it be?
Do I need to load it? If so from where?
All advice appreciated.
Tom.
