Doors object not cutting wall
I am trying to figure out why my door is acting differently in 2 walls which are identical. In the one it cuts the opening without issue, in the other the wall fill runs through the opening. These are the sames walls and doors. Any suggestions on what to look for. TIA
1 Solution
My guess would be that there are 2 walls one on top of each other. Try hovering and cycling the object selection with the Tab key.
Go to post
1 Reply 1
