EXPLODED DIMENSIONS IN ARCHICAD
I AM USING AC6.5 ON XP. I HAVE TRANFERED A FILE FROM ACAD 2002, BUT THE DIMENSIONS ARE EXPLODED IN LINES AND TEXT. ALSO FRACTIONAL DIMENSION ARE REPLACED WITH THIS "{}" CHARACTER. HAS ANYONE ANY IDEA HOW TO RESOLVE THIS ISSUE OR SOMEONE CAN DIRECT ME IF THIS HAS TOPIC HAS BEEN DISCUSSED BEFORE? THANKS
The exploded dimensions is a limitation of 6.5. I don't know what text "{}" problem is. Upgrade to AC10 and you will get actual dimensions.
I KNOW "{}" IS NOT AN ISSUE OF ARCHICAD. THERE MIGHT BE SOME SETTING THAT I AM OVERLOOKING. SOMEONE HAS ANY SUGGESTION?
