2007-11-21
04:36 AM
2023-05-30
03:20 PM
Rubia Torres
2007-11-21 05:04 AM
sanderarchitects wrote:two things you need to check:
I am trying to make our elevation markers be singular, as in one marker in the middle of a line instead of the double elevation maker(one marker at each end of the defining line) that I can't seem to get rid of. I can configure it to be a marker at the end of a line, or no marker and only a line, etc etc. We had this in 9, and now if I try to copy an elevation marker over from 9 to 10, it changes it.
Also, why is it that if I set the elevation to have infinite horizontal dimension, that it still stops at the ends of the line that I draw to define it?infinite 'horizontal' distance relates to the distance
2007-11-21 05:06 AM
2007-11-21 09:27 AM
sanderarchitects wrote:And please note, this is the default of the Elevation tool in AC11.
I am trying to make our elevation markers be singular, as in one marker in the middle of a line i...
