SOLVED!
Elevation marker lines
Strawbale23
Hi
Trying to find the setting to turn on the line between the marker heads.
I have turned it off or changed the colour, but cannot find the setting that controls this in the info box.
AC info box settings are a complete nightmare for finding settings. The layout is non
AC26
https://www.zendsign.fr/
10 REPLIES 10
@Miha_M wrote:
There is the option with two marker heads, but there is no option for a line connecting the marker heads.
True,
I just checked it and there is not control for the connecting line.
@Miha_M wrote:
However a section marker could be used for the same purpose.
Yes, sections and elevations are perfectly interchangeable.
Just don't fuss that they have their own section/elevation categories in the Project Map.
You can arrange them where you want them to be in the View Map (if you are not using cloned folders).
