Elevation marker
Hi everyone,
I am trying to configure our elevation marker like the ones in the image attached without success. Am I missing something? I would like to keep only a line on the base of the text. I hope I explained it right.
Thank you in advance.
3 Replies 3
Lingwisyer
Guru
AC version? Library?
It all depends on the marker you are using.
The 'built-in marker' only has certain styles - just text and a horizontal line is not one of them.
So you need to find one that does what you want or create your own with a bit of GDL wizardry.
Thanks Barry,
yes I was hopeful that I could change one of the existant ones with a "0" value somewhere to make one line disappear but I wasn't able to find one. For now I am not going to GDL it because I have almost no practice with GDL . Maybe when other more important parts of the template are finished and if I do, I am pretty sure I will end up here again...
