Error type - 7003: Plotting problem
When going to plot in ArchiCAD, sometimes (on certain sheets but not others) it says "Error type - 7003 occurred while creating plotter document"...(goes on to say the sheet name, etc). It won't let me plot from there. This has only happened a couple times before but is a major pain in the butt. Has this happened to anyone or does anyone know what this means?
2 REPLIES 2
to solve such problem i suggest you to install virtual pdf printer (pdfcreator for example or Amyuni that normaly ships with AC but it has some bug with italic when printing from AC)
So If all goes well problem is in printer driver or in the printer...
Found the problem. Turns out the name of the sheet was too long, I shortened the title and it plots fine.
