2021-09-07 01:57 PM
Hi all!
Is there a way to generate a list of the objects used, including the amount of each object, and the information assigned in the "product information" under "classification and parameters" tab in the object settings?
I hope to enter product name, supplier and price in this tab, and then easily export a list of all i.e. furniture I've used.
Tips?
2021-09-07 04:21 PM
You may want to look at this link to get you started... Interactive Schedules
You could also consider signing up at Graphisoft Learn if you are new to Archicad
2021-09-08 09:04 AM
Thanks! I'll have a look at the link.
Not new to Archicad at all, just never worked with lists before. Thought it might be time saving if I can get it to work the way I want... 🙂
2021-09-08 09:16 AM
Be careful of the terminology used.
'Lists' are something a little different - old method used before we had the 'Interactive Schedules'.
They still (sort of) work but are no longer being updated - so don't work with any of the new tools.
