Grid Line
I drew a number of grid lines on the plan. Some grid lines are shown on the sections and elevations but some don't. The one confused me further is for example Grid '1' shown in the floor plan and Section A but doesn't show up in Section B or Elevations.
Did you check the settings for Section/Elevation for these particular grid lines. You could accidentally turned off its markers. Or perhaps you have staggering the marks and your Section/Elevation have limited height.
Hope this helps.
Hope this helps.
I don't use grid lines, but isn't there something about them having to be parallel/perpendicular to the section elevation, otherwise they don't show?
I recall reading something here about it before.
If I can find the post I will add a link.
