ā2007-07-23
05:47 AM
ā2024-07-08
03:55 PM
Aruzhan Ilaikova
ā2007-07-23 06:57 AM
ā2007-07-23 08:17 AM
Rog wrote:wow!! i can see someone in progress !!
I have been using AC11 for two weeks.
I now know how to import the surveyors dwg into AC, how to create the grid outline polygon and how to trace the dwg contour lines onto the grid.
The 3d model of the terrain looks quite accurate.
I have also been able to cut a slab into the grid at any desired elevation.
and place a slab/roadway on grade by using SEO intersect and subtract.
Here is the new problem.
If the grid has a regular slope of 20% and I want to cut a slab at 10% into the grid, how do I do this?
How do I get a slab at a 10% slope to be able to use SEO subtraction with upward extrusion? A slab at 0% slope is the defaut?
Also I have found that when I create the mesh using 2ft contour lines from the surveyors data that the mesh triangulation becomes complex and slows down AC11 when refreshing 3d views.
Thanks in advance for any assistance.
ā2007-07-23 09:07 AM
ā2007-07-26 03:24 PM
