Help! Needing doors to show no label on electrical plan but remain on main plan
I'm not sure if I have posted this in the right area.
What I am looking for is help to make my door and window labels disappear when I switch to my electrical plan.
I have attached an image as to what/how my doors and windows are labeled now and what I need them to look like. I was trying to figure out a rule to allow this but I can not select "dimension" since in my marker area I just have show dimensions on.
I need them to have the labels when on the main floor plan but removed on the electrical plan
If anyone knows how to do this and can walk me through it simply would be wonderful!
Also usual Windows 10, Archicad 23
Jeff Griffin
This is handled via MVO (Model View Options). You would need to have separate MVO's configured for your main plan & your electrical plan. Within MVO, for your electrical plans, uncheck "with Marker".
See link below:
https://www.dropbox.com/s/0qurm5wm7hdisec/MVO.jpg?dl=0
iMac 27 (2020) 3.8 GHz Core i7; 128 GB RAM; Radeon Pro 5700 XT 16 GB GPU (macOS Sequoia)
MacBook Pro M1 Max; 64 GB RAM; 32-Core GPU (macOS Sequoia)
ArchiCAD 28/27/26/25 Full (back when Full used to mean Full) (latest builds). User since AC12 (2008).
Well, that was easy....lol. Thank you!!!
