Help with the Issue Index
Hello everyone,
I am trying to make an Issue Index but I can't make it work the way I want to. As I am relatively new to ARCHICAD I am not even sure it is possible.
I made 2 issues in the Issue History, A and B. As you can see in the issue Index when a Layout has 2 issue (both A and B) I get two lines for the same drawing where I would like ARCHICAD to override the first issue (A) when a Layout has the B issue.
Thanks,
AR
2 REPLIES 2
DGSketcher
Legend
See if the attached images help. The schedule content has been evolved from the UKI template Navigator > Project Map > Project Indexes > Layout List - Setout. I assume you have something similar in your template.
Thank you for your reply,
I understand, actually what I was trying to achieve was a bit different that this but I managed anyway.
