Hiding separator lines between wall and window
Hello!
We've been wrestling with this question for a while in our office... is there a way to hide the separator lines that appear between a window and its host wall in section / interior elevation?
In the attached images, an interior elevation viewpoint is shown -- one image with a graphic override active that applies a common cut fill and removes skin separator lines, and the other with no graphic overrides active. For clean airlines on interior elevations, it would be great to have the separating lines around the window frame & casing disappear too.
It seems almost as though we need to trigger a priority-based connection between the window and wall to get AC to read the materials as "intersecting", but I don't know of any ways to do this.
Any ideas?
Thanks!
0 Replies 0
