How do I edit the distance of datum in elevation?
In the attached file; how do I edit the datum line so I can push it closer to the building?
It's so far stretched off the building that it's taking out my elevation sheet.
Thanks
(File too big to attach)
Dropbox link of image
3 Replies 3
I assume you mean the story level lines. The distance from the building is defined by the extent of the Elevation Marker width and how far it extends past the building.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
You can offset the Story Markers out beyond the section / elevation extents, but you cannot set a negative offset to move them inwards
Thank you that makes sense!
