maxdunn
Layout Print > PDF Upside Down
An unusual occurence has been that my Site Plan View when inserted and printed to PDF turns upside down in the PDF. Only 1 sheet of 8 is wrong, the others are all OK. Having read the posts I changed from Bulzip back to the internal publisher and the problem was solved.
I don't know the cause though. The layout prints perfectly until I add the Site Plan View to the Layout. Then that Layout Flips.
Archicad 5,6,7,8,10,14,15,16, 19 + 20
i7 Win 7 8gb desktop GTX 970 Nvidia
i7 Win 10 16gb ASUS laptop 950Nvidia
0iiiiiii0
3 Replies 3
I have exactly the same problem! On several layouts the PDF output is flipped upside down, regardless of whether I print it or I publish a PDF from it!
Anyone has found the reason or has any solution for it?
Cheers
Katalin Borszeki
Hi All,
As it turns out the trick is in the settings. In the user's settings, the auto rotate/center option was turned on. If the auto rotate/center option is turned off, the printer will not turn pages upside down!! Tx, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
That's correct. I just found that out with Karoczkai Akos' help.
Also, the problem seems to disappear if the PDF is inserted in a worksheet as opposed to be placed as drawing directly in the layout.
Cheers.
