mollens
How do i add wall plate here
Hello. Im having trouble with adding a wall plate (or bottom chord, im not sure how to name it)  to this project. How may i do it ?
For these kind of detailed sections with wall framing/roof framing interaction, I usually use profiled walls with the components (incl. plate) drawn in.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
mollens
Hello. Thanks for the reply.
I've found this option but still i am unsure how to use it in order to create the wall plate. I'd be thrilled if you could elaborate.
Thanks in advance
