Importing Model Views
I'm having difficulty importing my saved model views from ArchiCAD 12 to ArchiCAD 13. Under the ArchiCAD 13 Model view options dialog I can see the the xml files for import, I select open and close the dialog but the model view settings are not imported. Does this Have anything to do with the new GDL objects options?
3 Replies 3
David Larrew
Try this work-around...
Open the AC12 file that has the Model Views in AC13. Then export out the MVs to an .XML file to be imported into the new AC13 file that you want.
David Larrew, AIA, GDLA, GSRC
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Thanks David, your work around did the trick
David Larrew
Glad to hear it.
AC 5.1-25 USA
