Invisible walls in layout (AC22)
Hi!
I can't see walls in a layout view. I pin the drawing of a plan to my layout and there are no visible walls. I think I have tried everything (which obviously is not true 😉 ) and found no solution. Any help?
Piotr T
4 Replies 4
Select the drawing in the layout, right click and choose 'open source view'.
If it opens correctly then the view settings are OK.
If not then it is the view settings that is the problem.
Make sure the view is set to the correct Layer Combination, Renovation Filter, Graphic Override Combination.
I assume you are saving a view of your plan and then placing that view with the drawing tools on your layout.
Thank You Barry!
I've found that I have used a wrong "construction stage" layers scheme.
For placing the drawing in my layout I use the attach drawing, or place drawing, (I'm sorry, I don't know how this tool is called in english). It is this one (You will probably name it by it's icon):
Piotr
Piotr wrote:
Thank You Barry!
This one is called the Renovation Filter
This is the "Link Drawing To..." icon.
It allows you to link an already placed drawing to any other view.
Re-linking to a different view will change the renovation filter and other settings (layers, etc.) as these are all saved with each view.
To place a drawing you should use the "Drawing" tool in the tool bar - or I just drag a view from the view map onto an open layout page.
Szabolcs Miko
I recall an issue in AC21, where if the Source View was open at the same time as the Layout, certain elements didn't show. That issue was related to Renovation Filters. The way to test it is to close the source view and update the Layout. Could it be that that is the issue?
Szabolcs Mikó
Manager, Customer Support
