Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Isolate Fill only
dhnguyen
I have 2D lines and fills on the same layer. If I use the "Quick Layers" tool and isolate the fill, the 2D lines also comes along with it instead of getting turned off. Is there a way to turn off the lines and keep the fills on?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
2 REPLIES 2
Only if they are in separate layers.
dhnguyen
thank you.
DNguyen
ArchiCAD 18- 25
