Label Tool in 22
Tim Ball
Anybody else had problems with text wrapping?
If I set text wrapping as the default using Autotext, then place a label, it doesn't wrap. The tick box unticks itself.
Tim Ball
AC26, iMac
User since V5
1 REPLY 1
I tried this and I see it working the following way:
- If you check the "Wrap Text" checkbox before placing a Label (Autotext or otherwise), the "Wrap Text" checkbox will become unchecked for the placed Label.
- If I then select the Label and check the "Wrap Text" checkbox, it will stay checked.
Is this how it works for you, too?
I can imagine this is how it is supposed to work and they reason it works like that is because it cannot Wrap Text until the Label is actually placed.
