Petros Ioannou
Layout marker referencing another Layout
Hi All,
I have a really large scheme so the elevations (and plans) needs to be split into several layouts.
What I am looking for is an object/marker which points to/reffers to another layout sheet.
Similar to the section marker on plan which refers to a specific layout.
So far we have been doing this manually so if you rename or rearrange the layouts you have to update these manually.
Let me know if you have any ideas.
Thank you.
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
David Maudlin
Petros:
You should be able to use Autotext Reference to accomplish this, in the Help files see: Autotext Reference Drawing.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Petros Ioannou
Thanks David,
I was I aware of the Autotext Reference but I thought it would only point at the Drawing ID but turns out it gives you the option to reference it's respective layout as well.
32 GB 2400 MHz DDR4
