Level Dimension Tool
The Level Dimension Tool used to work in section and elevation. Does anyone know of an alternative tool/object? There are cases when dimensioning just does not get the job done best from the point of view of graphic imagery.
1 REPLY 1
David Maudlin
Michael:
I don't think the Level Dimension ever worked in Sections/Elevations (I just checked AC 16, the Level dimension Tool is greyed out for Sections). Look at the Dimension Tool > Type & Font > Dimension Type > Elevation Dimension (right-most option), it has level dimension type graphic options.
You should add your ArchiCAD version to your signature.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
