Measure tool
rb51
Hi there!
I am having a weird one with the measure tool (probably a very simple fix?) - instead of measuring values between two items (eg: the distance between walls) it is measuring from what I assume is the project origin? How do I get it back to measuring the distance from 0 to the next object?
Thanks!
1 REPLY 1
I can never remember which option to select. Hopefully this page will be helpful to you.
https://help.graphisoft.com/AC/27/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC27_Help%2F140_UserI...
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
