Display malfunction of Graphisoft ID dashboard
Learn more
Merging dimensions
Hello fellow Archicad users,
I have the following question: how do you merge two adjacent dimensions in one? The dimensions are part of a longer dimension string but I don't wanna delete the entire row just to fix a part of it. I'm using Archicad 16 on Win7. Thank you in advance!
5 Replies 5
If I understand correctly you have two adjacent Dimension Units within a Dimension Chain. Let's say one is 1.20, the other is 1.50, and you want them to be one dimension of 2.70.
Click to select the Dimension Point between the two Dimension Units and press Delete.
Hi Laszlo! Yes, you understood right and I followed your instructions and here's what I got. I can edit/remove the two old dimensions which I don't need but the witness line between them is still there.
Then I suspect that two Dimension chains are on top of each other. The Dimension chain somehow got duplicated.
Just select one of them and delete it. The other should stay there.
It worked this time perfectly. It must have been a bug. The chain wasn't duplicated. But now everything's ok. Thank you!
Then it was probably a display quirk of some kind which disappeared when the display was refereshed.
You might want to make sure you have the latest graphics card drivers. This could be a driver glitch.
