Missing Nodes . Interior Elevations in Archicad 25
Has anyone else had issues with nodes missing in Archicad 25, specific to Interior Elevation Markers? I have projects in Archicad 25 and 24, but the issue only appears in 25. I have checked the obvious, Nodes and Snaps are all enabled. My Interior Elevations range go past objects. The only way for me to see nodes on objects is to select / marquee the entire area.
When I pan over the object the nodes are not triggered. This makes dimensioning Interiors impossible.  If I draft a hatch in this View, the nodes and dimension tool works fine. Is there a Setting that I can toggle?
Any ideas or input would be greatly appreciate. - Jakub
Archicad 25 - 4013 USA
Processor Intel(R) Xeon(R) W-2265 CPU @ 3.50GHz 3.50 GHz
ryejuan
screenshots would provide a better understanding. thanks.
WINDOWS 11 PRO
