Missing cabinet line at interior elevation
I am learning about creating Interior Elevations in AC 15 and am having problems with lines missing in the elevations. I have adjusted my lines on the floor plan to try to get them back but am having no luck. Is there something I am missing?
2 REPLIES 2
Nobody has an idea here why these lines might be missing? Could it be something with a video card, anything?
If you place a regular section at the exact same location as you interior elevation what do you see?
If it is the same then it must be something to do with you objects and elements making up the model.
If it is different then it is probably a setting or possible bug with the interior elevation tool.
The IE tool has had its problems in the past (and still does I believe although I think it is improving) and these may not have been resolved in version 15.
Personally I have never used it which is why I suggest trying a regular section to see if that is OK.
