Missing shadows on the windows in elevation ?
[/img][/img]The shadow falls proper on the door but not on the windows..
Is there any setting that I missed or the new AC 23 has a bug ? Never had this problem before..
Did anyone experience it ? Thanks for your help.
IC
Found it !!!
It was a setting in graphic substitussion.
6 REPLIES 6
Is it this setting in the window objects?
Just checked and it is not.
This just means if the widow actually casts a shadow or not.
Not if it can receive a shadow.
Are these all the same object and if so which one?
Hi Barry,
Thank you for your message.
I checked the setting and the shadow is checked in the menu.
These are the basic windows from AC 24. The project was created recently in AC24.
I have noticed, when I select the window, I can observe the missing shadow in the highlighted form.
Found it !!!
YS1616 wrote:
Found it !!!
Glad you found it.
So it was a Graphic Override that only affected the shadow on the windows but not the doors?
