Naming of Renovation statuses
This is a long shot but is there any way to change the renovation status text "To be demolished" to something shorter like "Demolished"?
Finding with schedules and auto-text labels it looks lengthy and a bit out of place.
For example "existing" doesn't say "remain as existing" and "new" doesn't show as "will be new".
GRAPHISOFT Certified BIM Manager | Senior BIM Specialist | LinkedIn
ARCHICAD 18-28 | BIMcloud | CI Tools | Grasshopper - Rhino | CloudCompare | Bluebeam
Australia & New Zealand
Windows 11 Business | Intel Core i9-13950HX @2.2GHZ | 64Gb RAM | 2x Samsung S27F350 1920x1080 60Hz | Nvidia RTX 4000 Ada Generation Laptop GPU (12Gb)
tjmillar
Can't help with what you're trying to achieve, but fwiw, if it's "demolished" it wouldn't exist anymore. "To be Demolished" is correct if it's still showing up in the drawings/model. It's not the same as "remain as existing" or "to be new" - which wouldn't be visible either - if it's not new yet, it doesn't exist 😉
Hope that's not too pedantic - I do think that sometime's Archicad's terminology is not quite right, but on this occasion I think it's correct.
AC26 Australia, Windows 10
Thanks TJ
That does help. Sometimes just being able to justify it in my mind is enough, can then use that same justification when explaining to others.
