PBC of duplicated module on floors above and below
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2022-01-10 06:31 AM
As per the subject. We have a project that has duplicated the floor plan over 10 stories and we are finding that the module is not performing PBC to itself. We have check the settings and obvious issues which are set correctly. Are there any non-obvious settings that must be set for this to work?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-10 10:52 AM
@strom32 The non-obvious settings may be obvious to others. You might want to be a bit more specific about your PBC issues, it could be something really simple or it may be a known issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-10 12:27 PM
What number has priority of module Master Layer of the module? It interferes with PBC. It shoud be set to "0" othervise it will change priorities of object layers in module.
www.sieberttalas.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-12 01:41 AM
Hmm, I thought that would work and tried it but it didn't. Your reply is a example of non-obvious solutions that if correct should be included in the Archicad Manual. We can't find anything in the manual that would assist us in this instance. All media that we can find for PBC demonstrates PBC with non-moduled models and no complexity.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-12 01:43 AM
I should mention too that the module has no problems with SEO to elements that are not within itself and that are not other modules.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-12 01:44 AM
I should mention too that the module has no problems with SEO to elements that are not within itself and that are not other modules so far.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-12 04:52 AM
Modules are notoriously bad for maintaining building materials. If a material name is changed (duplicated) on import due to a mismatch, however minor, the building materials will not merge.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-12 04:58 AM
Is your module geometry and placement absolutely accurate? Even a tiny drafting error will create joint lines.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-12 09:10 AM
Samplel of your file would help in search for solution. Can you share it?
It is quiet interresting problem. We use modules a lot and I have never experineced a major problem with PBC so it will help us prevent them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-01-13 12:13 AM
We place our storey modules in the same model on the negative levels. So they exist sub-tereanean and are then published and hotlinked into the model on the positive levels. So we suspect Building Material mismatches are not possible with this method.
