Aula
Pen problem
Hello all,
I'm using Archicad 22 and have an odd problem.
One of my drawings is has peppermint green lines and hot pink fills, even though when I select the items, it claims they are pen 1 (black; which they should be). So if I select a green line and CTRL+T, it will state it's pen 1, although it is clearly not. If I go to any of my other drawings - same project, but on other sheets - the pens are fine (pen 1 for lines, fills varying shades of grey): basically, the visuals are the same as the parameters that show up when I CTRL+T
I have no idea what to do, so any help is most appreciated!
Thanks,
Aula
1 Solution
Lingwisyer
Guru
Check your Graphic Overrides  and Renovation Filters?
Go to post
Lingwisyer
Guru
Aula
Thanks for the suggestion - my Graphic Overrides was configured incorrectly! THANK YOU!
