Plotting Marquee area or current view
Hello,
I started working with archiCAD like 7 weeks ago everything went fine till I got a new Computer. Some settings are different but everything went fine except one thing:
My question and problem is:
When i have a drawing and I want to Print/Plot a Area. It will show me on preview: Marquee current view blank only the parts above the areas is printed.
So when I want to print something i must make a kind off line from a Marquee area to print, plot or save as PDF, Otherwise I would get a blank with nothing i want on it.
Does anybody have a clue how to fix this or has a similar problem.
Thank you for reading and hope someone has a solution.
10 Replies 10
The answer is (at least for Version 10.0) that there are two versions of Archicad 10. One is for PPC processor machines and the other is for the Intel based machines. When you use time machine or firewire to move from the PPC machine to the Intel machine Archicad moves and works relatively well. The print above marquee is one of the problems. Fortunately I did not use the PPC version long enough to find other problems.
