Possible to change text in multiple details at once?
Does anyone have a way to change text in many details without going trough every detail.
Waiting for your help
Thanx
3 Replies 3
You have to do it detail by detail.
The quickest thing you can do is select all text at once in each detail by activating the text tool and pressing CTRL+A.
If you want to change the properties of the text you have to do it for each detail.
If you want to change the content (e.g. change a word or phrase) use the "Search and Replace Text" function in the Edit menu, fill in the "Find text that contains:" and "Replace with" fields and hit the Replace All button.
Yes sorry, I read the original post as change the font style, colour, size, etc.
To change the content do as Stuart suggested and it will automatically go through all sections, details, storeys (if you tick that option), etc.
