David Collins
Print Marquee Area problem
Print Marquee Area from the 2d window no longer works for me. The printer spits out a blank page which I suspect is actually an empty area somewhere on the screen. I've recently switched to both AC20 and Windows 10, so I don't know who to blame.
Update: I had rotated the plan view 90 degrees which seems to have confused the marquee. Bringing it back to 0 degrees solved the problem. Was this always an issue?
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
Katalin Borszeki
Hi!
This issue has been foxed in build 3532 and is planned to be included in the upcoming update! In the meantime as a workaround turn back the rotated view. Best, k
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
