Renovation Palette
I've been searching, and googling for the past 2 weeks trying to find an answer to my question, so hopefully someone on the forum can help me out.
I built my original floor plan, used the renovation palette to demo walls, and then create my new construction model. My problem is I'm trying to get my new construction plan to pull into the publisher set, but it only displays the existing or the demo, and never the new construction, no matter the palette setting I have.
I guess my question is, is there a way to make my new construction plan, the main floor plan, or am I better off exporting it as a dwf / dwg and importing it into a new project.
Thanks
Christina
1 Reply 1
Aaron Bourgoin
Christina,
Have you created Views to place on Layouts? Views have settings for Renovation Filters which should let you see what you want to see on each of the sheets you create.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.32 Mac
MacOS Tahoe 26.5.1
