Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
dhnguyen
Renovation style override pen thickness
My 3D walls and 2D lines are set to be "demolished" under the renovation status. They are on the same renovation style override, which has a thickness of .40mm. How do I make my 2D lines show up thicker? - please see attached image, thank you.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
5 Replies 5
Hi dhnguyen,
Check menu View > On-Screen Options > True Line Weight and see the real line weight of your pens.
There is also an option for bold cut lines. I you donยดt want, uncheck it.
Hope that helps.
dhnguyen
Thanks for your response. I had it set to "true line weight".
I noticed that if i changed the original color of the 2D line into the same yellow color that I selected for the renovation style overwrite, then the lines will show up with the same thickness as the 3D wall lines... But then that defeats the purpose of not being able to use the default "Existing Plan" Renovation Filter Option.
All of my lines will have the same thickness under the existing plan.
DNguyen
ArchiCAD 18- 25
this is happening in a Layout view, right?
Check the renovation rules for similar yellow colors...
David Maudlin
dhnguyen:
AC18, an older version, does not have the option to Override Pen Color Only, which is available in AC23. Somewhere between these two versions this option was added.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual โ€ข Mac mini M4 Pro OSX15 | 64 gb ram โ€ข MacBook Pro M3 Pro OSX14 | 36 gb ram
dhnguyen
I see, thank you, my limitations.
DNguyen
ArchiCAD 18- 25
