!Restored: Grid Tool - missing col grid
We're having an issue where our column grids are missing from our south elevation. The layer combination settings are the same for the south as they are for the n/e/w. Is there way a to "re-insert" them?
thanks!
Laura Yanoviak
We had this problem in AC10 -- the only remedy was to place a new Marker and recreate the View.
Djordje
thanks!
Grid System or Structural Grid?
Which Archicad?
Which OS?
Please put the Archicad and OS versions in your signature.
For example, there is a significant difference in the Grid System tool for 10 and 11, so it is essential to know which Archicad you are on if the answer is to be correct. Be specific in questions, and you will get specific answers.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
