kylevfa
Set wall override to only effect outside line of wall but not openings?
I am looking to spruce up my elevations by adding a variety of different line weights for the walls, however I have noticed that when setting an override on the wall element not only does the outline of the wall change but so does the outline for any openings made by windows/doors. Is there some sort of rule I can set up in my graphic override combinations to not override these openings?
0 Replies 0
