Showing elevation in meters for autotext labels
Is there a way to make autotext label to show elements' elevation in meters rather than millimeters?
My dimension settings in preferences are set to meters for elevations but that stupid label seems to use calculation settings instead. Basically I can't find a way to display element's width(mm) and elevation(m) within a single label.
Funny, that 'elevation label 21' uses the dimension settings and shows everything correctly. But I can't set it up the way I want. This is very frustrating. Does anyone see a working solution?
Thanks,
Max
0 Replies 0
