Size setting of label outline in elevation is grayed out
Hello fellow ArchiCAD 19 users.
This is my first post here since I can't find existing answer online.
I need to label windows and doors in the elevation, but hexagon size is too small to fit the text (window ID) and the setting (that I think represents it) is grayed out (see screenshot)
Also graphic standard of our office requires me to rotate the hexagon so that flat part is on top and bottom (like I sketched in a screenshot.)
I was able to do all that in plan, but in elevation it is a mess, please help.
Thanks
P.S. I have been using archicad for little over a year (part-time), so please explain in terms I would be able to understand
4 REPLIES 4
(Not an answer to your question, but you can delete your duplicate posts before someone comments on them)
David Maudlin
Artur:
It looks like you could use the Identification Label 19 to get what you need, turn the Frame on. I think the NCS Indicator 19 is a fixed size, the Identification Label 19 changes size to fit the text.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you David Maudlin
it worked
and I did a signature like yours
David Maudlin
Artur:
Glad to read that you found a solution, thanks for posting back and adding the signature.
